Use the following procedure to save the configuration file or log file to an external USB device.
Caution
Always use the usb-stop command to safely unplug the USB drive from the USB slot.
Switch:1#save config file /usb/test.cfg CP-1: Save config to file /usb/test.cfg successful. WARNING: Choice Primary Node Config file is "/intflash/soak.cfg". Switch:1#
Switch:1#save log file /usb/test.log Save log to file /usb/test.log successful. Save log to file /usb/test.log successful. Switch:1#
Variable definitions
The following table defines parameters for the save command.
Variable |
Value |
config file WORD<1–99> |
Specifies the software configuration device and configuration file name in one of the following formats:
The file name, including the directory structure, can include up to 99 characters. |
log file WORD<1–99> |
Specifies the software configuration device and log file name in one of the following formats:
